Random Renderings (+ An apple a day)
Started by Esben Oxholm, April 28, 2016, 07:37:34 AM
NM-92
Here it goes. I've split the surfaces for you, so all the walls can function as lights if you wish or be textured individually. Ceiling has some insets where lights can be applied too. I normally use this with an all black HDRI, and sometimes i add a backdrop ramp inside as well. I usually duplicate some of the planes if i need to highlight any specific spot. Hope it helps !
nicordf
Quote from: NM-92 on August 11, 2016, 01:46:31 PM
That file is gold!!! Use it wisely;)
Esben Oxholm
Thanks a lot NM-92. Very kind of you.
It's great, but didn't manage to create anything serious with it, yet :)
Quote from: nicordf on August 11, 2016, 03:22:21 PM
Haha, I will!
A few new renderings (Mouse model from grabcad and Lamp from http://sorenrose.com/download-3d):
Arian Shamil
That lamp.........A M A Z I N G  :o
I really love it!
Despot
Agreed... the lamp is a thing of elegant beauty :)
Finema
beautiful work and details in textures
+1 for the lamp  ;)
bdesign
Superior work, Esben. I love how you usually add a bit of particulate matter to your renderings...really makes the realism pop :)
Cheers,
Eric
DMerz III
Yes good point on that Eric, love the specs of 'dust'.
Esben, what is your usual process for adding that detail, is it post? is it a label with an opacity channel tied to the camera perspective?
Maybe you've shared this somewhere else, apologies if this question is redundant.
Esben Oxholm
Quote from: Arian Shamil on September 07, 2016, 09:14:38 AM
I really love it!
Quote from: Despot on September 07, 2016, 01:33:50 PM
Quote from: Finema on September 07, 2016, 08:50:53 PM
+1 for the lamp  ;)
Quote from: bdesign on September 07, 2016, 09:08:35 PM
Cheers,
Eric
Thank you so MUCH, guys. Really appreciated.
Quote from: dmerziii on September 09, 2016, 08:54:12 AM
In the past I've added it in post, but I've recently started to do it directly inside KeyShot by layering materials and using a dust 'overlay' texture as an opacity map. I did a short tutorial yesterday on this proces. Check it out here:
https://youtu.be/5EDJkN6SPLA
Finema
Really good tutorial
Thanks Esben  ;)
Despot
+1
Been doing something similar to this for a while now, but not with dust :)
NM-92
I've been doing it this way too and i am pretty happy with the results. Playing with the brightness/contrast of the opacity map gives you control over the visibility of the dust to achieve different effects.
Will Gibbons
Esben Oxholm
Thank you guys!
Quote from: NM-92 on September 15, 2016, 06:43:57 AM
True. I totally forgot that part. I gotta have a basic script next to me next time I'm doing a tutorial :)
Actually, I usually use the 'color to number'-node instead of adjusting brightness/contrast as I find it easier to control.
Will Gibbons
[quote
[/quote]
I've just started using the color to number and have to agree. It's powerful.
