Mitsubishi Lancer Evo X
Started by NM-92, April 28, 2016, 08:58:15 PM
Josh3D
Quote from: NM-92 on May 10, 2016, 09:55:44 AM
Too much noise and really dark.
An emissive inside the headlamp might help.
NM-92
Well, this came out. Emissive didn't work, but glass did the job, almost (that black spot, i have no idea what it is, but i'm kinda ok with that).
Heretic Templar
Damn those last renders look really unique.
Great work
NM-92
Quote from: Heretic Templar on May 10, 2016, 08:15:38 PM
Great work
Thank you man  !
NM-92
New shots. Playing a little bit.
Magnus Skogsfjord
That's pretty cool! Another thread with great progress.
NM-92
Quote from: Magnus Skogsfjord on May 12, 2016, 11:51:52 PM
Thank you Magnus. I can't stop playing around with this model :P . I still need to try some detail shots.
As an experiment, i tried applying some chromatic aberration to this image.
NM-92
NM-92
I agree! Great progress and those last ones look like some pretty clean marketing renderings. I still second an earlier comment that the tires look too inflated. Try the technique mentioned where you move a ground plane up a bit and clip the geometry that's under the ground plane. This way the treads won't be visible on the part of the tire that's in contact with the ground.
Really love those last ones.
NM-92
Quote from: willgibbonsdesign on May 16, 2016, 08:34:02 AM
Thanks ! I totally forgot about that ground plane tip. I'll try it with the next automotive render (66´Mustang) that is currently in progress.
Quote from: NM-92 on May 16, 2016, 04:27:10 PM
Cool, can't wait to see it!
