Harmonica
Started by Finema, August 03, 2016, 08:30:58 AM
Finema
A test with textures only in Keyshot...
Finema
an other one in a warmest environment....
Despot
Nice harmonica, but the obvious repeating pattern on the ground plane is very distracting
Finema
Yes you are right  ???
i've correct it  ;)
NM-92
Metal is looking great. I find the wood a bit strange though. Is the texture set in box mapping mode ? Light setup is also really good.
Finema
Thanks Nico  ;)
Yes i've a problem with wood material in Keyshot  :(
NM-92
UV mapping is the only way i found to get decent results. If you have a small radius to map, spliting surfaces and mapping individually often do the job, but with rounded corners i still haven't found an easy way to get it right.
Finema
Yes UV mapping is the best but it's a model to Grabcad and when i put it in C4D to create UV it's the misery  ;)
I've change the mapping mode of the wood texture
I hope it's better now.
In attachment 2 other tests.
Thanks again
NM-92
Yes ! 'harmonica.45.jpg' looks awesome now.
Finema
Finema
I've added a little blue light and 2-3 corrections
Finema
here a black and copper version...
Finema
with vinyls records...
nicordf
Hey Finema! Looks awesome but the timber still needs a bit of a bump map in my opinion. Try increasing the gloss to 18% (wouldn't know how much is that in roughness haha but wood on an harmonica has to be at least hand oiled) and adding a 0.15 bump to it so the darker seeds on the grain insets a tiny bit. Timber can be tricky sometimes when not using uv mapping.
Oh! By the way, that label detail looks incredible!!!
Finema
Thanks Nicordf
i will test... ;)
