Author Topic: Bright scene - white in the infinite  (Read 6481 times)
Offline Robertoo
« on: November 07, 2016, 01:21:23 pm »
Hi, I need help to do such a substrate with light. Can anyone help ?
Offline Will Gibbons
Re: Bright scene - white in the infinite
« Reply #1 on: November 07, 2016, 01:27:23 pm »
If I understand you correctly, you want to recreate the ground/background?
1. Add ground plane.
2. Apply material/textures to ground plane.
3. Press 'c' on your keyboard to apply white background.
4. Apply gradient texture to ground plane as opacity texture.
Offline Robertoo
« Reply #2 on: November 08, 2016, 12:24:06 pm »
If I understand you correctly, you want to recreate the ground/background?       - YES
1. Add ground plane.        OK,
2. Apply material/textures to ground plane.                              -> ok
3. Press 'c' on your keyboard to apply white background.               -> ok
4. Apply gradient texture to ground plane as opacity texture.            -> HOW ?
« Reply #3 on: November 08, 2016, 12:48:04 pm »
Not a valid vimeo URL
Offline Robertoo
« Reply #4 on: November 08, 2016, 01:00:55 pm »
Thanks !!!
« Reply #5 on: November 08, 2016, 01:46:33 pm »
Thanks !!!
Sure. Video was faster to capture than actually writing out the steps, so no problem.
