Bright scene - white in the infinite
Started by Robertoo, November 07, 2016, 01:21:23 PM
Robertoo
Hi, I need help to do such a substrate with light. Can anyone help ?
Will Gibbons
If I understand you correctly, you want to recreate the ground/background?
1. Add ground plane.
2. Apply material/textures to ground plane.
3. Press 'c' on your keyboard to apply white background.
4. Apply gradient texture to ground plane as opacity texture.
Robertoo
Quote from: Will Gibbons on November 07, 2016, 01:27:23 PM
If I understand you correctly, you want to recreate the ground/background?       - YES
1. Add ground plane.        OK,
2. Apply material/textures to ground plane.                              -> ok
3. Press 'c' on your keyboard to apply white background.               -> ok
4. Apply gradient texture to ground plane as opacity texture.            -> HOW ?
Will Gibbons
Will Gibbons
Quote from: Robertoo on November 08, 2016, 01:00:55 PM
Thanks !!!
Sure. Video was faster to capture than actually writing out the steps, so no problem.
