Author Topic: RealFlow-Cinema4D > import animation in keyshot  (Read 4734 times)
Offline Finema
« on: December 07, 2016, 12:23:25 am »
Realflow integration in Cinema 4D R18 is fun to do liquid animation directly in C4D.
I've tried to export a test file in Alembic format but Keyshot 6.1 don't want to open it.
What's the process to import it in Keyshot ? and , is it possible ?
  • Guest
Re: RealFlow-Cinema4D > import animation in keyshot
« Reply #1 on: December 07, 2016, 07:00:07 am »
Yes - the alembic format is supported but not deformable animations. For now you will need to export an obj sequence and then import and render it using scripting inside of KeyShot.
In KeyShot 7 we will have a native support for deformable animations though. If you have an example that you can share we can give this a try and show you the results.
Offline Finema
« Reply #2 on: December 07, 2016, 07:58:38 am »
Thanks Thomas
I join an Alembic file exported from C4D. It's just a test not a complete work  ;)
  • Guest
« Reply #3 on: December 07, 2016, 08:02:36 am »
Cool - I will test and post the results.
Offline Finema
« Reply #4 on: December 07, 2016, 10:06:02 am »
Thanks a lot.
  • Guest
« Reply #5 on: December 07, 2016, 11:51:27 am »
Here it is.
Offline Finema
« Reply #6 on: December 07, 2016, 07:43:33 pm »
Whaoouu, great Thomas. It's direct import in Keyshot 7 ?
How i can test the beta Keyshot 7 ?
Thanks a lot.
  • Guest
« Reply #7 on: December 08, 2016, 05:56:37 am »
Yes - direct import. You can play it back in realtime, and render it out.
There is no BETA for 7 just yet. We will keep you informed when there is.
Offline Finema
« Reply #8 on: December 08, 2016, 06:41:12 am »
Thanks again Thomas  ;) i'm waiting for...
