Jaggies in the reflection
Started by Johnjoti, January 24, 2011, 05:50:33 AM
Johnjoti
I hope development team will fix a bug in the KS 2.2
Johnjoti
#16
2,2 is already finalized?
KeyShot 2.2.33 final?
Bug is not corrected!!  ???
Johnjoti
Now I understood whence jaggies came
When I run the render from the Rhino, then is generated bip file old type and jaggies are present
But if I open a new project is not out of the Rhino, but from the root directory and import the geometry, then no jaggies
Blame the old plug-in for Rhino
For the sake of interest I checked it on the 2.1.25
In a new project is not out of the Rhino, jaggies do not appear
This example is different. You need to increase your tessellation inside Rhino.
Johnjoti
Quote from: Thomas Teger on March 10, 2011, 07:32:41 AM
What do you mean?
Johnjoti
Here render from the Rino
Here I imported the same storage geometry from the bip file into a new project
I attached the file that generated when rendering from the Rhino
You can import geometry from this bip file to a new type file
and make sure that jaggies are formed is not associated with tessellation inside Rhino.
Use standard HDRi "HDRLightStudio_car_studio_medium"
Jhon G
JeffM
Thanks for the update!
Could we get the Rhino file as well?
Johnjoti
Of course
