Author Topic: Ryzen R7 1700 at stock settings 123.8 FPS  (Read 3749 times)
Offline joseph
« on: March 30, 2017, 02:59:59 am »
I was finally able to put it altogether today. Running at stock auto settings on the motherboard. Set at high performance on W10 Power options.
Offline joseph
Re: Ryzen R7 1700 at stock settings 123.8 FPS
« Reply #1 on: April 09, 2017, 04:15:30 am »
Memory now set at 2666mhz, with XMP enabled. Can run along with IRONCAD for hours without the temps going beyond 45°.  I haven't tried on the Wraith Spire cooler as I installed the Be Quiet Rock Pro from the pervious build. I have no plans of overclocking the processor. System a lot quiet than my previous FX8370 build and doesn't put my 550W psu past 80%. The Eaton 5E 850i ups output load is at 163-170W on idle with 263W load on Keyshot rendering. Two panels, a Philips 273V & 243V are also plug to the ups.
I am using a customized balanced power plan with minimum power state set at 18% from the default 5%. The standard Balance and AMD Ryzen Balanced palns sort of trims the single core boost clock on the R7 1700.
« Last Edit: April 13, 2017, 04:42:56 pm by joseph »
