Good evening Keyshooters,
I have a rhino file with hundreds of mesh surfaces (one on top of the other) and when I import the file in to KeyShot (v6) I can render each instance of the surface. This is fine but it takes a long time.
The mesh actual deforms from the next file. The end result is a fluid surface when viewed in sequence. Rendering each instance as a separate image file is very time consuming. The images are then imported into After Effects for composing into one animation.
Is there a work flow online that anyone can share to show me how to script the rendering of each mesh?
The mesh(es) are created using rhino/grasshopper and the native file is a rhino .3dm file.
Any help or direction would be greatly appreciated.
