Author Topic: is there any short way to turn off all refraction  (Read 2613 times)
Offline Öner
« on: May 30, 2017, 11:23:35 pm »
Hello again,
at first, i want to thank you for your help all time, thanks for your time.
i want to make an animation and don't want any refraction for all material, is there any short way?
« Last Edit: May 31, 2017, 04:09:12 am by tokuz »
Offline Will Gibbons
Re: is there any short way to turn off all refraction
« Reply #1 on: May 31, 2017, 07:10:19 am »
Hello again,
If you've applied the glass material to an object, in its material properties, there's a checkbox called 'two-sided'. Uncheck that and you'll have turned off refraction for that material.
Offline Öner
« Reply #2 on: June 01, 2017, 12:13:00 am »
No mate,
i mean that i want to apply the short way to all material at the same time.
« Reply #3 on: June 01, 2017, 07:03:23 am »
Why not use a Toon, flat, or diffuse material? There's no way to not render reflections/refraction in KeyShot.
Offline Öner
« Reply #4 on: June 01, 2017, 07:09:49 am »
sure i can use flat or toon or diffuse material for all model in scene.  But i want to adjustment the degree of reflection at the same time for all material.
