Author Topic: Decal applied as texture not showing up in rendering (ver 2.2.42)  (Read 6116 times)
Offline o-lab
I updated to ver 2.2.42, and experiencing a problem with decal feature.
I applied JPEG image as a PC screen content and it looks OK in real-time mode.
However, when I render it, the decal (applied as "texture") does not show up at all.  Instead, it shows a blank gray area.
Another issue I have is that when I apply the decal as texture using UV-map, it shows up as a repetition of millions of super-micro graphics.  Thus, I increased the scale U and V up to about 200 and it looks OK.
However, then when I tried to shift the image using "sift U (or V)", it only allows entering between -5 and 5, so the only way I could "roughly" position the image at the right place is dragging using "position."
I sometimes need to be able to control the placement and scale by very precise numbers, so please fix the bug as soon as possible!
Thank you.
  • Guest
Re: Decal applied as texture not showing up in rendering (ver 2.2.42)
« Reply #1 on: March 03, 2011, 05:38:49 pm »
Go to "check for Update" under the help menu, and download the latest version - 2.2.45.
Offline o-lab
« Reply #2 on: March 04, 2011, 09:03:21 am »
Updating to 2.2.45 solved the issue.  Thanks!
