Plexiglass
Started by DeteZvezda, March 06, 2011, 07:46:20 AM
DeteZvezda
Hello.
I am trying to get the plexiglas material right. This is the best i can do, but its not accurate enough. I am using Solid Glass with IOR 2.38. Does anyone have a better material...
TNX
I suggest using the Gem or Dielectric materials. You want control over the Abbe number. The Abbe number gives you the dispersion that you see in plexiglass.
Use the following settings:
IOR - 1.5 - 1.51
Abbe - 34
Increase your raybounces in the realtime tab (12 should be enough), and turn on "detailed indirect illumination".
I found these numbers on the internet.
Hope this helps.
Thomas
DeteZvezda
Thanks for a quick reply. It get better. Still i get the black edges, and the color is white...
I am trying to make sompting like this ...
Increase your raybounces. It also depends on your lighting.
DeteZvezda
Burkhard
Change your light settings similar to your original.
The reflections of the blueish Background is what you see.
DeteZvezda
I try that too. Blue is just a backround color, enviroment is pure white HDR file...
32 raybounces
detailed indirect illumination checked
default HDRI lighting
Ground shadows turned off
Gem material - IOR 1.51, Abbe 34
The dark reflections you see is from the reflection of the environment.
How's that?
DeteZvezda
 :) ... U sure showed me ...  :) .
Thanks a million ...  ;D
Glad to hear it helped!!
DeteZvezda
It seams that problem is not solved. Sendig the example...
Here is the link to a file. If someone can get it right, i wold like to see it... :)
http://www.sendspace.com/file/z0ux5x
JeffM
Depending on the angle you view your model at, 32 ray bounces may not be enough to illuminate all the edges. Try outputting a render with the bounces set to 64.
DeteZvezda
 ;D;D
Thank you ALL... I O U 1 ...  ;)
JeffM
Looks great! I'm glad we could help :)
