Keyshot 7 Network Renderer - Error This Packet type should not be forwarded
Started by Mario Stockinger, August 07, 2017, 02:07:19 AM
Mario Stockinger
We upgraded to Keyhot 7 and NW Renderer 7.0438
When i send a job to the network there is no Progress transferring the job to the network. After 12 Minutes it times out.
In the log there are a lot of errors.
We had no problems with keyshot 6, no AV running.
Any Ideas ?
Hi Mario,
Please get in touch with support@luxion.com for this issue.
I presume you are keeping everything (Manager, Workers, Monitor) inside a single LAN?
Also, it always helps if you can share the scene data with us.
Mario Stockinger
Thx for the reply - its a 4GB Bip File.
I'll contact luxion
The Render Manger/Monitor PC and the Render 01 - 04 (Workers) PC's are on the same lan. (192.6.1.xxx)
The Keyshot PC that sends the job to the Master PC is on a different IP  (192.168.30.xxx) bit is also a Worker
With keyshot 6 it was no problem at all
Hi Mario,
I believe we identified the root cause for this issue and have fixed it.
We will issue a new build shortly.
Marco,
Can you try and install this new build (7.0.442)?
https://www.keyshot.com/?ddownload=335654
Let me know if this solves your issue.
Mario Stockinger
Mario Stockinger
The new version is not working.
The Error on the Monitor / Manager seems gone (No errors in the Log) , no red x icon.
On the workers i get an error. Attached the log
We could do a teamviewer session if you want to check configurations  - that would be possible.
We would like to test your scene ourselves first.
You can send via https://keyshot.wetransfer.com/. Send to dries@luxion.com.
You can only send 2GB at a time. If your ksp file is larger than 2GB, then you can use e.g. 7-Zip to split it up in smaller volumes.
Mario Stockinger
It is 1 7zip file
I'll send you the passwort per pm.
I tested the step file i used for import - with keyshot 6 the bip file has double the size as in keyshot7.
The optimization in Keyshot7 is nice.
The biggest Keyshot6 bip i work with  has 11GB and was no problem to send through NW Renderer to our Render farm...
When you open the bip you'll see that there are problems with "ä, ö , ü"
The step file import had problems with this letters. This was fixed in an earlier version of keyshot6 bit but was broken in a later update and not fixed in keyshot7.
Edit :
My Workstation is a dual socket Xeon System with 28 Cores  + 28Cores HT  (2.4GHZ)  and 128GB Ram and a PCIe ZDrive
Mario Stockinger
Mario Stockinger
I testet with different tessellation settings for my 3rd Project - 1Gb  - 4GB
I also set the IP's for Direct connection as you advised.
I did a test rendering with the 1GB Bip file in 4k - that worked.
Then i tried a different project with a 4 GB Bip file.
The files seemed to be transfered to the workers but after a few minutes all workers lost connection to the master and on 3 workers
the Process crashed and got stuck like yesterday when we did the teamvierwer session.
On my PC i only use the Monitor - every few Minutes i lost connection to the master and the monitor reconnected.
On The Master PC i got an error message  - not enough memory   (It has 8GB Ram) - WIth KS6 NW Renderer i never had memory issues on the master.
The Master is a VM - so i'll set it to 32gb RAM for testing
Ill attach a few Logfiles from the workers / Master pc
Hi Mario,
Could you give an overview (as detailed as possible) of your Network Rendering setup?
  • What are the specifications of each machine? CPU, RAM etc.?
  • Does every machines have sufficient free storage?
  • Are all machines running Windows 7?
  • Is only the Manager a VM?
  • What is the network infrastructure? Are all machines on the same LAN?
I know it is a lot of information, and I think I already know some of it, but I want to get the complete picture.
Mario Stockinger
Render Master is the only VM
Render Master and Render 01-04 are on the same lan  (192.6.1.x) . Keyshot PC is in the Normal Workstation lan (192.168.30.x)
Render01 - Render 04 have 48GB Ram and at least 160 GB free Disk Space. (Old ESx Servers)
Render 01 is an old single socket Server  with total 4 Cores  (No HT)
Render 02-03 are Dual Socket Servers with 2 CPUs  total  8 Cores (No HT)
All Cpus have 2.4 Ghz
Keyshot Workstation PC has 128GB Ram  256GM PCIe Drive    Dual Socket with 2 CPUS total 28 cores no HT    , 2.8GHZ not sure.
Render-MAster is a VM , 32GB Ram 40GB free disk space.  8 Cores no HT 2.4 GHZ
All machines are running W7
Thank you for the information.
Do all machines have Gigabit Ethernet?
