Striations on final image
Started by JamieN, August 10, 2017, 03:57:29 PM
JamieN
I am getting some weird striations on my final image. I have no physical lights and using the startup hdri. Anyone know what might be causing this?
Hard to say what is going on. Is that in 6 or 7?
JamieN
#3
 Does the bottom part material has any bump or normal texture applied? Then try to reduce the depth value a bit.
I guess you run full simulation lighting preset?
Use a simple one. No caustics, no global illumination, just simple 6 ray bounces.
Hope that helps
