KSv7 realtime window: images are soft/blurred.
Started by jhiker, August 16, 2017, 06:04:19 AM
jhiker
I'm posting this in the 'Bugs and Issues' section because I can't imagine it's deliberate.
Images in the 'realtime' window on Keyshot v7 are much softer than in Keyshot v6.
In fact they look like they have had a large amount of 'bloom' or a small amount of 'blur' applied by default. The image from KS6 looks slightly out of focus to me.
Consider these two very similar images from the realtime windows in both KS6 and KS7. The one from KS6 looks much sharper.
They both have the 'Product' lighting preset applied and the same lighting environment. 'Image effects' and 'Lens effects' are OFF in both cases.
I can't think of any other setting that might be causing it.
I notice the 'Product' lighting preset settings for KS6 and KS7 are, in fact, slightly different, as follows:
KS6                                 KS7
Self shadows ON              Self shadows ON
Global illumination ON           Global illumination ON
Shadow quality 1                   Shadow quality 3
Ray bounces 10              Ray bounces 14
Indirect bounces 1                   N/A
Ground illumination OFF      Ground illumination ON
For the purposes of the comparison I turned Ground illumination ON in KS6.
Now, I much prefer the image from the KS6 realtime window. If I want to apply bloom or DOF or whatever I'd like to do it myself - I want the basic image to be 'unprocessed' and sharp.
Can someone from Keyshot tell me what's changed and why. There must be something different going on here with the rendering engine, I think.
I've attached an image from KS6 and KS7 and a sort of 'side-by-side' comparison. The differences can be clearly seen in the highlighted areas (and elsewhere).
If this can't be fixed I might well choose to remain on KS6.
Many thanks.
jhiker
I'm a little disappointed that Keyshot haven't commented even to acknowledge the issue or tell me I'm wrong  ;)
have you tried emailing support@luxion.com? That is the most direct way to get individual assistance.
This is strange. I am not seeing this with my scenes on my own machines. ???
Let's get to the bottom of this.
It would be great if you could share the scene with us. So that we can check if the issue is maybe scene-related.
You can share via WeTransfer. Send to dries at luxion dot com.
jhiker
Quote from: DriesV on August 17, 2017, 12:47:09 PM
Thank you. I'll open the model in both KS6 and KS7 and save a  KSP package from each along with a screen shot(s).
Esben Oxholm
I haven't noticed this myself during the beta testing, but saw someone post on facebook about is as well.
Seems not to be a single incident.
Hope it'll be an easy fix for you!
jhiker
Esben, I'd like to read that. Could you pm me the link please?
Esben Oxholm
Quote from: jhiker on August 18, 2017, 11:46:52 AM
Can't make a direct link, but if you go here: https://www.facebook.com/groups/keyshot/ and search for 'Bukhari Torro' (in the left sidebar), it is the post from 9 August at 05:34
Let me know if you find it.
Despot
Might it be a texture related issue ? the bloom seems to be in areas where label textures are - unless of course it's geo and not labels.
Just my two cents...
jhiker
#9
Quote from: Esben Oxholm on August 18, 2017, 12:01:05 PM
Got it! Seems like a couple of people have noticed this. I sent a couple of scenes to Keyshot and they have been very helpful. They are investigating.
Despot
I think I'll change my name to Claude Rains...
jhiker
adamwade
Yes, we are also noticing the KS7 realtime view is lower quality (jagged edges and softer labels.  Also we are seeing that the overall materials in our scene are more contrasty.  Even the same HDZ background is producing different reflections with the exact same settings.  I have a support email I'm still waiting on.
jhiker
Quote from: adamwade on August 21, 2017, 03:23:46 PM
Are you comparing KS6 with KS7 as I am?
Keep us posted....
Furniture_Guy
jhiker,
I too have had a problem with images not as sharp as version 6. Support gave me a link to a newer version of 7 which helped quite a bit but they're still not up to version 6 quality...
