Author Topic: Animation question  (Read 2053 times)
Offline zooropa
Animation question
« on: September 04, 2017, 07:16:04 am »
I am new with KS and I am planning to buy a pro license. I need to do a few animations.
I never experienced that aspect of the software. Please find attached different samples of which movements I am looking to achieve.
Please if you know that my goals are possible (the model is coming from Rhino) I will consider to proceed to buy it.
I just wanted to verify this before investing now, if not I will wait to BF.
If you check one of the animations needs to move through a guide. Is it possible to build elements paths so they move where I want them to move?
Thanks so much.
« Last Edit: September 04, 2017, 08:22:17 am by zooropa »
Online DriesV
  • Administrator
  • Total likes: 29
Re: Animation question
« Reply #1 on: September 04, 2017, 09:01:00 am »
Number 2 and 3 should be possible with a custom pivot object (e.g. a hidden sphere, set as the rotation center. Circular/spherical movements are no problem.
The translations look straightforward.
One limitation with Rhino in general is that it lacks local origins for individual parts. This could make animations more challenging. But it all depends on your actual product structure and design.
MCAD tools like Creo or SOLIDWORKS do not have this limitation.
« Last Edit: September 04, 2017, 10:24:59 am by DriesV »
Offline zooropa
« Reply #2 on: September 04, 2017, 10:55:59 pm »
Thanks for your answer. These are examples. The number 3 will not be an arc. Is it possible to describe a path not originated by a sphere?
Online DriesV
  • Administrator
  • Total likes: 29
« Reply #3 on: September 05, 2017, 12:25:25 am »
That will currently be difficult to achieve.
KeyShot's current toolset for Part animations is optimized for translations and rotations.
However, we do support importing of animations for a number of file formats. If you build the animations in e.g. Modo, then you can export to Alembic or FBX to get the animated model into KeyShot.
Offline zooropa
« Reply #4 on: September 05, 2017, 12:47:33 am »
This files are coming from SW. Do you think if they come from SW is possible to make them go through a path ?
Thanks so much.
Online DriesV
  • Administrator
  • Total likes: 29
« Reply #5 on: September 05, 2017, 01:42:53 am »
Unfortunately SOLIDWORKS Motion Studies cannot be exported to KeyShot at the moment.
Offline zooropa
« Reply #6 on: September 06, 2017, 07:11:47 am »
Thanks a lot for the fast reply!
