[RESOLVED] - Triplanar Mapping
Started by cjwidd, September 21, 2017, 11:37:33 PM
cjwidd
If you want simultaneous projection from all three axes (XYZ), is it really necessary to assign the same texture file to each field in the triplanar node, or is there a way to wire a triplanar node to a texture map node to save clicks on this operation?
soren
Any axis without an assigned texture picks up a texture from one which is assigned (if any).
In practice, just set the X axis texture and the others will get the same texture and size and the angle can be varied per axis.
Søren
cjwidd
