1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Plugins
3ds Max
Keyshot 7 plugin not working in 3dsmax 2018
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Keyshot 7 plugin not working in 3dsmax 2018 (Read 5831 times)
OccultMonk
Newbie
Total likes: 0
on:
October 01, 2017, 05:58:52 am »
Keyshot 7 plugin installer does not install to 2018 (Latest installer) .gup file was also not in the 3dsmax 2018 directory. The help .txt states that 3dsmax 2018 is supported.
Last Edit: October 01, 2017, 06:06:59 am by OccultMonk
Logged
OccultMonk
Newbie
Total likes: 0
Re: Keyshot 7 plugin not working in 3dsmax 2018
Reply #1 on:
October 09, 2017, 11:51:33 pm »
Has anyone installed this into 3dsmax 2018.2? It does not create the key shot menu and the plugin is also not installed in the 3dsmax folder. The .ini file states that it is compatible with 3dsmax 2018.
Logged
Guest
Reply #2 on:
October 10, 2017, 06:22:33 am »
We have a fix for it. Should be available later today.
Logged
Fabbrica
Newbie
Total likes: 0
Reply #3 on:
October 12, 2017, 06:33:43 am »
Having a similar problem with Keyshot 7 and 3DS Max 2018.3. The .gup file is located in the plugins folder of the Max program files, but no menu options appear in Menus drop down of Customize UI.
Logged
feher
Hero Member
Total likes: 0
www.keyshotstudios.com
Reply #4 on:
October 16, 2017, 03:10:03 pm »
Have the same problem here. 3dsmax 2018 plug-in will not work.
Tim
Logged
Guest
Reply #5 on:
October 16, 2017, 03:56:38 pm »
Autodesk insist on changing things mid-release which has a tendency to break 3rd party plugins. I just posted an updated plugin:
https://www.keyshot.com/resources/downloads/plugins
There is a known issue when transferring cameras. This will be fixed in KeyShot 7.2.
Logged
feher
Hero Member
Total likes: 0
Reply #6 on:
October 24, 2017, 06:29:04 pm »
Thanks Thomas. Will try this out.
Logged
feher
Hero Member
Total likes: 0
Reply #7 on:
October 24, 2017, 06:36:15 pm »
Yup it's working now !!! WHOOP WHOOP
Logged
Print
Pages: [
1
Go Up
« previous
next »
KeyShot Forum
Plugins
3ds Max
