Author Topic: Keyshot 7 plugin not working in 3dsmax 2018  (Read 5308 times)
Offline OccultMonk
« on: October 01, 2017, 05:58:52 am »
Keyshot 7 plugin installer does not install to 2018 (Latest installer) .gup file was also not in the 3dsmax 2018 directory. The help .txt states that 3dsmax 2018 is supported.
« Last Edit: October 01, 2017, 06:06:59 am by OccultMonk »
Offline OccultMonk
Re: Keyshot 7 plugin not working in 3dsmax 2018
« Reply #1 on: October 09, 2017, 11:51:33 pm »
Has anyone installed this into 3dsmax 2018.2? It does not create the key shot menu and the plugin is also not installed in the 3dsmax folder. The .ini file states that it is compatible with 3dsmax 2018.
« Reply #2 on: October 10, 2017, 06:22:33 am »
We have a fix for it. Should be available later today.
Offline Fabbrica
« Reply #3 on: October 12, 2017, 06:33:43 am »
Having a similar problem with Keyshot 7 and 3DS Max 2018.3. The  .gup file is located in the plugins folder of the Max program files, but no menu options appear in Menus drop down of Customize UI.
Offline feher
« Reply #4 on: October 16, 2017, 03:10:03 pm »
Have the same problem here. 3dsmax 2018 plug-in will not work.
Tim
« Reply #5 on: October 16, 2017, 03:56:38 pm »
Autodesk insist on changing things mid-release which has a tendency to break 3rd party plugins. I just posted an updated plugin:
https://www.keyshot.com/resources/downloads/plugins
There is a known issue when transferring cameras. This will be fixed in KeyShot 7.2.
Offline feher
« Reply #6 on: October 24, 2017, 06:29:04 pm »
Thanks Thomas. Will try this out.
Offline feher
« Reply #7 on: October 24, 2017, 06:36:15 pm »
Yup it's working now !!! WHOOP WHOOP
