Author Topic: settings of the scene  (Read 3332 times)
« on: October 21, 2017, 05:30:24 am »
I have a problem with getting a realistic rendered interior effect. In attachments I present PrtSc with interior settings. I would be very grateful for your help :)
« Last Edit: October 24, 2017, 01:17:34 am by DanieloDanielo123 »
  • Guest
Re: settings of the scene
« Reply #1 on: October 24, 2017, 06:36:12 am »
Can you please upload the scene the way you set it up? The attached scene in the KSP has only default materials assigned.
Thanks.
« Reply #2 on: October 24, 2017, 10:15:43 am »
HI,
Thank you for your answer, in the attachment I send the scene.
Regards,
Daniel
« Reply #3 on: October 24, 2017, 10:29:36 am »
I'm sending the correct format  :)
Thenks,
Daniel
  • Guest
« Reply #4 on: October 24, 2017, 11:36:23 am »
I noticed that your walls are very shiny. Try dialing down the specularity.
« Reply #5 on: October 24, 2017, 01:13:19 pm »
I'm sorry but I do not understand what I have to do ?  ( Try dialing down the specularity ) ?
  • Guest
« Reply #6 on: October 24, 2017, 06:00:40 pm »
If you double-click on the material you will see that the Specular color of the plastic is set to all white. If you make it grey you will notice that it gets much less reflective.
