Author Topic: 'Visible to Camera' problem with emissive material  (Read 4427 times)
Offline lopster
« on: November 05, 2017, 02:41:14 pm »
Hi guys!
I'm new to keyshot and there is a little problem i can't figure out right now.
I've added geometry to my scene and added an emissive material to use it as a light.
Therefore I've disabled 'visible to camera' so only the emitted light would be visible.
The geometry is still visible though. i.e. my sphere with the emissive material shows up as a white circle.
Is this meant to be like that and if so can i somehow only render the lighting without having the geometry show up at all?
Hopefully someone can help me out, since i couldn't find any info on this.
Thanks in advance!
Offline INNEO_MWo
  • Total likes: 85
Re: 'Visible to Camera' problem with emissive material
« Reply #1 on: November 05, 2017, 11:06:05 pm »
 I can't figure out the exactly problem. Is there geometry with a high reflective material near the emissive part?
Maybe some screenshots would help us to help you?!
Offline Will Gibbons
« Reply #2 on: November 06, 2017, 08:14:18 am »
Hi guys!
Thanks in advance!
Make sure you update your KeyShot software to the latest version. If I recall, this was a bug in a previous version that was fixed.
  • Guest
« Reply #3 on: November 06, 2017, 10:06:59 am »
Correct - this has been fixed in 7.1.51.
Offline lopster
« Reply #4 on: November 06, 2017, 11:45:21 am »
oh wow that did the trick ::) thanks a lot guys!
