Rolling ball animation - rotation problem
Started by robinlou, December 09, 2017, 04:07:23 PM
robinlou
I am testing a simple animation of a rolling ball into a hole. Although I have all axes set to "Original Local" the ball rotates around some other axis instead of its own center as a result of the transition. When I turn off the transition animations, the ball rotates as I want it to.
Attached is my bip file.
Öner
hello, i've tried to make it as you want.  Please click on pivot point object axis instead of dynamic pivot point, and axis will be X.  i hope it's what you want.
