Author Topic: Computer Mouse  (Read 6974 times)
Offline wddr
Computer Mouse
« on: June 12, 2011, 01:19:58 pm »
Modelled mainly in Solidworks, a couple of surfaces in Rhino. No Photoshop.
Offline feher
Re: Computer Mouse
« Reply #1 on: June 13, 2011, 03:17:30 am »
Just a wonderful set of images ! They have a nice feel to them. You can really get a sense of how the material will look and feel.
NICE work. Thanks for sharing.
Tim
Offline Speedster
Re: Computer Mouse
« Reply #2 on: June 13, 2011, 09:06:40 am »
I ditto Tim's comment!  Really nice modeling, which, as a SolidWorker, I fully appreciate.  This is the first time I've seen a well modeled and rendered PCB with all the goodies.  I've got to look into Rhino more!
Offline wddr
Re: Computer Mouse
« Reply #3 on: June 14, 2011, 05:18:22 am »
Thanks for the appreciative words. I'm in the process of rebuilding my website, so going through a few old projects and making new renderings. I'll add some more as they get made
Bill - don't focus too much on the Rhino comment... Five years ago I used Rhino a lot, but Solidworks' surfacing tools have improved a lot, so I rarely find the need nowadays. It's only when I can't get the right transition between surfaces in Solidworks that I go into Rhino to patch the surface in. But as I say, the times when I need to that are far fewer than they used to be.
Matt
Offline quigley
Re: Computer Mouse
« Reply #4 on: June 15, 2011, 03:20:12 pm »
I recognise that mouse....is this Matt from "We Don't Do Retro"?
Offline wddr
Re: Computer Mouse
« Reply #5 on: June 17, 2011, 10:57:51 am »
ah no, rumbled... ;)
Offline repman
Re: Computer Mouse
« Reply #6 on: June 24, 2011, 02:35:52 pm »
I have one question, how/where did you apply those textures to the PCB and other components.
I also work with Solidworks, but I didn't find a way to apply a material/texture to only one part of a surface unless I use an assembly, then I can apply materials/textures to objects within assembly in KeyShot.
Did you model each component independently and put them in an assembly before running KeyShot?
Offline Speedster
Re: Computer Mouse
« Reply #7 on: June 24, 2011, 03:48:27 pm »
Hi repman;
This may or may not apply to the beautiful mouse (never thought I'd say that about a mouse!) but here's a great, and little known, SW trick I often use.  Use the "split line" command in SW to create the exact surface you want to map. Just throw a sketch on a plane or surface, then use the command and select the surface you want it on.   It can be anything- I often use it for lettering, for example, that I want as part of the geometry, not as a decal.
Offline repman
Re: Computer Mouse
« Reply #8 on: June 25, 2011, 07:30:41 am »
Hi repman;
Thank you for your reply, I'm not exactly sure if I understand this command (I did go through SW Help file and had a look at the command), do I have to make another sketch just to split another object/part?
I made a simple object just to describe a bit what I want:
Let's say I wanted to assign the top surface (the selected one) as steel in keyshot and everything else as aluminium.
Right now I can't do that since if I import the part into keyshot it sees it as 1 body (can't apply materials to only one surface).
Is there any way to assign those surfaces as bodies or something so that I can apply different materials/textures in Solidworks.
P.S: sorry for hijacking the thread a bit
Offline Speedster
Re: Computer Mouse
« Reply #9 on: June 25, 2011, 01:38:04 pm »
You need to "color map" the surface in any given color, to tell KS this is "different".  Here's a sequence set of screenshots as an example.  Let us know how it works out for you!
www.GouldStudios.com
Offline repman
Re: Computer Mouse
« Reply #10 on: June 25, 2011, 02:15:18 pm »
Got it working now, I really appreciate your help, thank you.
  • Guest
Re: Computer Mouse
« Reply #11 on: June 26, 2011, 06:29:05 am »
@Speedster - thank you very much for helping the community.
Offline Speedster
Re: Computer Mouse
« Reply #12 on: June 26, 2011, 07:38:59 am »
You're most welcome, Thomas!
You know, we're all in this together, and each of us brings a unique skill set to the table.  This is an active forum on which we all share so we may all excel and succeed, and I for one have learned a lot here.  Most importantly, this is a productive and professional forum, with very few rants and personal attacks so common elsewhere.  Ours is a friendly, professional, community sharing a stong common interest and bonded by KeyShot.
Sorry for waxing philosophical here, but I've been in business for 38 years now, through many ups and downs.  I have been helped along the path by many, and I try to return that as well, to honor our past as well as our help others along their path.
Offline trice1
Re: Computer Mouse
« Reply #13 on: June 27, 2011, 09:29:14 am »
I fully agree with you Speedster, wax on any time!
Offline wddr
Re: Computer Mouse
« Reply #14 on: July 03, 2011, 12:25:38 pm »
Apologies for not replying earlier, I've been on holiday and trying my hardest to avoid any kind of internet connection. But Speedster has explained things at least as well as I could, and basically I follow exactly the process he's described. I almost always 'model' graphics, logos etc in Solidworks (using the 'split surface' command) after bringing in artwork from Illustrator. This is a bit of a hangover from Hypershot when decals weren't very reliable, but actually I don't think it takes that much longer, and it gives a lot more control.
And in the spirit of sharing tips... here's a great resource if you don't know it: http://www.brandsoftheworld.com/. Almost every logo you could possibly imagine, for free as a downloadable .eps
