First animation
Started by zooropa, December 23, 2017, 12:20:34 PM
zooropa
Hi. If you have any suggestion I am open to listen.
I am not sure about the light. I render it at only 35 samples cause my laptop...its going to explode.
https://vimeo.com/248595080
Arian Shamil
Did you ever figure out what the issue was with the first animation? This seems to be better.
zooropa
Quote from: Will Gibbons on December 27, 2017, 07:58:12 AM
Yes . The error was fixed when I switch off 'render background' mode. Strange bug.
Quote from: zooropa on January 02, 2018, 09:58:05 AM
That is strange. Good to know. FYI, unless you must work in KeyShot while it's rendering, there's no reason to use 'render in background'... it'll just slow down your render times.
zooropa
Quote from: Will Gibbons on January 03, 2018, 06:57:17 AM
Great tip Will! Thanks .
PS. Do you think the animation is too dark ?
Quote from: zooropa on January 03, 2018, 10:13:15 AM
Not necessarily. I personally keep my monitors on low brightness until it's time to do final lighting and post-processing. If I turn my monitor up, it looks good, but I tend to err on the brighter/more contrast side just to be safe. If you've got your animation or frames in an editing program, that's an easy fix!
zooropa
