udim maps setup
Started by naghi, December 30, 2017, 01:03:45 AM
naghi
Hi
Is there any way to import udim maps to keyshot?I couldnt do that.
Not that I'm aware of.
Can you explain what results you can achieve with UDIM that you can't with regular UV? We are looking at enhancing texture mapping in KeyShot 8 and would love to hear any feedback or feature requests. The more specific, the better.
naghi
Udim maps are more than just one shel.we can use as many as texture sets.I couldnt import that kind to keyshot.
soren
The Tiled UV node (in KeyShot 7) supports tiled UV layouts. It supports the following naming schemes:
Indexed: e.g. "diffuseu0_v0.jpg, diffuseu1_v0.jpg, diffuseu0_v1.jpg". You do not need to use _ but anything with uXX and vXX should work (more or less).
UDIM: e.g. "diffuse1001.jpg, diffuse1002.jpg, diffuse1011.jpg"....
The Tiled UV node is more advanced then the regular Texture Map node with options for texture filtering. By default, images are assumed to be in linear color (which is not the case for the Texture Map node).
Hope this helps.
Søren
