Author Topic: Can't place label on multiple objects after duplicating them  (Read 2965 times)
Offline klaasjanklaas
« on: January 25, 2018, 05:53:37 am »
Hello everyone,
I've got a quite strange problem.
I am trying to place 1 label on 4 different objects.
Normally, that would not be a problem, because I know that when materials are linked, the label extends to all these linked materials.
However, this time it won't happen. I started my project with 2 objects. I duplicated those 2 objects, so that I have 4.
Now, when I'm trying to place 1 label on those 4 objects (2 normal, 2 duplicates), it seems impossible.
No matter what I'm trying, the label always appears twice (1 time on the first 2, on time on the duplicated ones).
Things I've tried:
- Unlinking all materials, applying different materials on each object, then link them with a new material.
- Not only duplicating the assemblies, but also the actual parts on which the label has to be (so that they all have different names).
- Different mapping types
See image attached for my problem.
Note: I duplicated the assembly BEFORE putting on a label.
Is there someone who also experienced this problem and/or knows a way out of this?
I would be glad.
Regards,
Klaas-Jan
Re: Can't place label on multiple objects after duplicating them
« Reply #1 on: January 25, 2018, 06:57:22 am »
can you post a package of your project? So much easier to see what is going on if we can dig into your project itself.
« Reply #2 on: January 25, 2018, 07:14:59 am »
Hi mattjgerard,
I made a .ksp file, but it is too large for attachments (68MB)
I put in in my google Drive, here you can download it:
https://drive.google.com/open?id=12V06zXB3f6Hjj4vHQtwozk7v_sZATOn1
I'm using Keyshot 7.2 Pro Floating by the way.
Thanks in advance!
Klaas-Jan
« Reply #3 on: January 26, 2018, 01:45:04 am »
I (sort of) fixed it by putting the same label on all 4 individual surfaces and then shifting them so that they look like 1 image.
For now, this is a possible temporarily fix, but not the normal way to go. The issue remains..
Offline Will Gibbons
« Reply #4 on: February 01, 2018, 10:52:32 am »
I would go about it like this:
1. Link all 4 surfaces
2. Map the image onto it via cylindrical mapping
3. Adjust the diameter to match that of the 'cylinder' (if your 4 surfaces were wrapped into a full cylinder)
4. Center on model (not part) will allow the texture to see all 4 surfaces as a single piece.
« Reply #5 on: February 01, 2018, 11:58:25 pm »
Hi Will,
I know, I tried most methods already.
The problem is in step 1 and 4: the surfaces will not link so that they will be seen as a single piece.
I think it has something to do with the fact that I duplicated the assembly, but I still don't understand.
In the mean time I managed to solve my problem in another way. But thanks!
Offline DriesV
  • Administrator
  • Total likes: 36
« Reply #6 on: February 02, 2018, 01:10:06 am »
Hi Klaas,
I was going to suggest that you could group all your models together and that it would then work, but it doesn't. :)
This appears to be a bug and we are looking into it.
