Author Topic: Animation: Translation + Rotation Bug?  (Read 2503 times)
Offline dshugoplt
« on: March 06, 2018, 08:31:26 am »
I am having trouble creating an animation with a translation movement followed by a 180º rotation.
I made a simple assembly to explain the problem.
After the translation of the small cylinder, I created a 180º rotation with a pivot point on the center of the big cylinder which is static.
The part should rotate around the big cylinder, but it looks like the pivot has moved.
Any suggestion would be helpful
Offline Esben Oxholm
Re: Animation: Translation + Rotation Bug?
« Reply #1 on: March 06, 2018, 11:40:03 am »
Not the optimal solution, but if you move the part (using the move tool) to the left and then animate it back into position as a 'pre-animation-setup', then it rotates as expected after the translation if I understood you correct.
Take a look at the bip.
Cheers,
Offline dshugoplt
« Reply #2 on: March 07, 2018, 01:20:08 am »
Not sure if this will work for me.
Because my animation is too complex and I have this type of movement in the middle of the video.
But I will give it a try.
https://www.keyshot.com/forum/index.php?topic=3602.0
It seems Keyshot have this problem at least since 2012  ???
« Last Edit: March 07, 2018, 03:30:33 am by dshugoplt »
