Export HDRI
Started by cjwidd, April 06, 2018, 05:50:13 PM
cjwidd
I saw in an older thread that the dev team was looking into exporting HDRI from Keyshot. Is there any progress on this feature?
Quote from: cjwidd on April 06, 2018, 05:50:13 PM
In what capacity? It's been implemented since 7.0 as far as I know. You won't get the option if you're using a protected image (like any of our HDRI images in the KeyShot library). Try exporting one using your own image assets or a procedural environment and you should see the option.
cjwidd
Right, I was interested in exporting a custom HDRI and using this method was sufficient. That being said, it was a helluva a workaround, so I was curious if exporting HDRIs to a more generic file format (e.g. TIFF) had been implemented.
soren
With the limitations Will mentions you can export to hdr and exr formats in KeyShot 7 (not tiff though).
In the environment tab, under the HDRI Editor sub tab there is a button to the far right which will do the export.
/Søren
