Resolution Presets
Started by onkar2608, May 25, 2018, 03:38:03 AM
onkar2608
Does Keyshot 6 Resolution Presets changes if I open keyshot on a different configuration machine?
I rendered on a different machine as mine was not a powerful one.
The results came out in a different resolution than what I had set.
DMerz III
Do you mean for the real-time view? That is usually dependant on the screen resolution, smaller screens with less pixels will automatically shrink your real-time viewport if needed to fit. However, when rendering you can set the resolution to be whatever you want as output.
You can check real-time viewport settings under the Image tab.
