Author Topic: Lighting Query  (Read 1959 times)
Offline solutola
Lighting Query
« on: June 03, 2018, 05:33:48 am »
I;m fairly new to keyshot and am trying to play around with the HDRI editor. However, in this scene one of my models is completely black no matter which environment I choose or rotate. It's like there isn't enough light but even adding another light object isn't helping? Would really appreciate help on this :)
Offline INNEO_MWo
  • Total likes: 19
Re: Lighting Query
« Reply #1 on: June 03, 2018, 09:18:11 am »
Hello.
The size of the environment, ground size and the additional ground plane was not big enough.
Changes were:
- environment to 16450 mm
- ground size to 20220 mm
- ground plane scale to 20
Hope that helps
Offline solutola
Re: Lighting Query
« Reply #2 on: June 06, 2018, 06:49:50 am »
Hi Marco,
Thanks for your response. I'm not sure how you change the environment size? I think I've fixed the other two.
Offline INNEO_MWo
  • Total likes: 19
Re: Lighting Query
« Reply #3 on: June 06, 2018, 09:12:44 am »
Just look through the environment tab of the project dialog and you’ll find that two parameters that defines the sizes of environment and ground.
