Author Topic: [RESOLVED] Alembic export - from Cinema4d/Realflow to Keyshot7  (Read 3130 times)
Offline trappistmonk
  • Newbie
Hey guys  :)
I have an issue that i could not solve.
I created a really basic Realflow scene in Cinema4D. I cached the simulation and the mesh and the export it.
I have this message "error code 7 : Your file does not contain 3D geometry..." when i try to import in KS.
I can see all my baked frames in the cinema4d cache folder. I can import frame by frame and see the mesh but impossible with the sequence...
Is there anyone with a solution ?
Thank you!
« Last Edit: May 02, 2019, 01:46:09 pm by Ian Reymond »
Offline mattjgerard
Re: Alembic export - from Cinema4d/Realflow to Keyshot7
« Reply #1 on: August 08, 2018, 01:58:09 pm »
I'm not sure if PLA is exported via Alembic in C4D, that's a good question. Is the mesh being animated via PLA or otherwise?
does the sim play in the C4D timeline?
what are the settings in your Alembic export box?
  • Newbie
« Reply #2 on: August 09, 2018, 02:29:10 pm »
Finally found a solution on CGTalk... maybe it will help someone else !
1) Cache your simulation
2) Select the MESHERS folder
3) In the export settings,  check "Selection Only" and "Merge Generated".
Keyshot should open your ABC file. It worked for me.
Offline mattjgerard
« Reply #3 on: August 10, 2018, 06:58:37 am »
Excellent! I played with realflow a while ago, and it was fun to try but I had no practical use for it in the work I was doing. Glad you got it figured out and even gladder (?) that you posted your solution for others to find.
cheers!
Offline PeterSwift
  • Full Member
« Reply #4 on: August 14, 2018, 03:42:41 am »
Must be an export issue, maybe you baked in the wrong way. I'm not super experienced with C4D but It works fine for me. I just another plugin in C4D though. HOT4D.
Offline Cynthia23
  • Newbie
« Reply #5 on: February 02, 2019, 01:05:31 am »
An excellent suggestion! psiphon
« Last Edit: February 03, 2019, 08:33:15 pm by Cynthia23 »
