SketchUp plugin won't load
Started by chippwalters, August 04, 2011, 01:18:42 PM
chippwalters
After I installed the KeyShot plugin for SketchUp, then launch SketchUp, I get the following error:
Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/KeyShotExporter/keyShotExporter.rb
126: The specified module could not be found.   - C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/keyshot_sketchup_plugin.dllError Loading File keyshotExporter.rb
chippwalters
I've confirmed there is a SU plugin file keyshotExporter.rb in my SketchUp 8 Plugins directory as well as the file keyshot_sketchup_plugin.dll.
Also, there is a folder KeyShotExporter in the same Plugins directory with the files:
keyShotExporter.rb
  (yes, same name but different capitalization from the one mentioned above..hmmm)
Lastly, the installer also added the file unist.exe to the KeyShot2/Plugins/SketchUp directory.
chippwalters
I guess I should also add the fact that even though I've confirmed the location of the plugins, it still doesn't load and gives the same error message as the first post in this thread.
Also, I am NOT using any other KeyShot plugins (don't know if that means anything).
Still looking into a solution for this ...
chippwalters
Thanks a bunch. Just curious, does it work on your end? If so, are you on a 64-bit computer as I am?
chippwalters
archkuja
same here. doesn't work on my mac parallels
@archkuja - But KeyShot is running?
@chippwalters - yes we are on a 64bit computer as well.
archkuja
yup. keyshot is running fine. The problem begins when i start sketchup. The plugin won't load. Same problem with chip, although I'm using lots of plugins.
archkuja
chippwalters
How about at least telling us if the SketchUp plugin is working at all on any platform? And if it is, what are the particulars?
Of course it is working. I am running it on Win7 without any problems. We have a fix for it which we are currently testing.
chippwalters
chippwalters
Thanks for the update! Works like a charm :-)
