wallmount light
Started by Elaheh Elmy, September 29, 2018, 11:20:52 AM
Elaheh Elmy
happy to hear your words
Elaheh Elmy
aaaand the texture
scanner
Texture is good, but why the basis hangs over a wall?
Elaheh Elmy
Quote from: scanner on September 30, 2018, 08:42:05 AM
Thank you, that's not my design... I just recreated a lamp I saw but that was good point
Eugen Fetsch
scanner means that there is a gap between the lamp base and the wall.
scanner
Quote from: camomiles on October 01, 2018, 12:40:53 AM
Yes, I meant it.
Elaheh Elmy
Aaaw I see, I didn't notice... I'll fix it thanx
Elaheh Elmy
Quote from: scanner on October 01, 2018, 02:25:56 AM
Yes, I meant it.
I get it now, thank you for pointing it out,I'll fix it
kiarash.tamizkar
Khob start zadid,vali zamanetono roye karaye chalesh bar angiz tar bezarid be nazaram shayad zamane bishtari vase upe kar be vojod biad vali avazesh chizaye bishtary yad migirid.
DMerz III
Nice texture work!
Are you using an IES profile on the light emission? I think that could elevate the image even more if you had a cool IES profile light coming from the lamp, not sure if that's what you're going for though.
Pouya Hosseinzadeh
Lookin' tough. Absolutely love that!
As your friends mentioned, you have to spend more time on details...
The distance between wall and wall light
Simulation of light and balloon material
As well as focusing on textures and mapping types
و همچنین شما تو گروهی هستید که میتونید کارهای زیباتون رو اونجا بفرستید تا لذت ببریم و دور هم چیزهایی رو یاد بگیریم
نترسید اصلا چنین فردی نیستم که پست ها رو پاک کنم و یا از گروه بندازم بیرون  :)
Anyway, I wish you all the luck in the world.
Elaheh Elmy
Quote from: kiarash.tamizkar on October 01, 2018, 06:15:27 AM
mamnoon, hatman
Elaheh Elmy
Quote from: DMerz III on October 01, 2018, 08:34:58 AM
Nice texture work!
aw thank you, the aim of the render was the surface texture but you're right and I'll try to improve it as you said
Elaheh Elmy
Quote from: PouyaHosseinzadeh on October 01, 2018, 10:38:04 AM
motshakeram, hatman
rembem
Sorry, but I've seen better images from you!
