Frosted or rough surface glass with gloss text label? How?
Started by markw, November 15, 2018, 01:45:07 AM
markw
I can put a glossy label on to an opaque surface, I am not sure if I am doing it the best way as when I change the white label on transparency png to blend with the main plastic colour each time.
Now I want this effect on frosted or rough surface clear materials.
bharris
I would use the image to drive the roughness channel of the material.
Since KeyShot 6 we can apply these as a label with a glossy material onto a rough material (surface) using the onboard label features.
So I can achieve this with a simple label.
markw
This is the effect I would like to achieve.
markw
Here are some options I received from support.
How about this?
For details check the attached package.
Hope that helps
markw
Fantastic, so much going on in the material graph I did not understand!
