White outlines around PNG
Started by PeterSwift, December 07, 2018, 01:28:03 AM
PeterSwift
Does anyone know why with transparent PNG, some get this defect that when using it as a label a text get a white boarder around each letter.  It's exported from Illustrator.
Any ideas what we are doing wrong or is it just a bug?
TGS808
I don't think I've ever had anything like this happen. Can you post an image of the results you are getting so we can see what you're referring to?
Francisco
Quote from: PeterSwift on December 07, 2018, 01:28:03 AM
Hello PeterSwift,
If you can would you be able to share an image of what you are getting? Also, you mention that you get the text file from making it in Illustrator and was looking to see if I could find anything. Would you be able to set the text blend mode to "Multiply" in the Transparency or Appearance Panel?
Let me know if that helps resolve the issue? Also, if not can you still post the image?
Furniture_Guy
Converted text to outlines and has a stroke with a color of white perhaps?
Perry (Furniture_Guy)
