Author Topic: Softening the displacement  (Read 2182 times)
Offline Josip_ZG
« on: January 14, 2019, 01:30:51 am »
Hi, everyone. I have a question about the way I can add more versatility my surface imperfections.
I want to create a worn screwdriver and I've found a map that would do okay. The displacement map height is in negative value and the same map is used as an opacity map on a label material, so I get the effect of a material that is worn and torn so much that another material is visible under it.
The problem is that the texture I used is too monotone, so the transition between dark and light value on edges is very harsh. How to make the fall-of effect on edges? Can it be done in Keyshot somehow, maybe with occlusion texture? I attached the render and the texture. No post-processing was applied.
Thanks,
Josip
Offline RRIS
  • Total likes: 5
Re: Softening the displacement
« Reply #1 on: January 14, 2019, 03:22:14 am »
I use photoshop with the 'outer glow' layer effect on a new layer with my selection.
Offline Josip_ZG
« Reply #2 on: January 14, 2019, 05:23:32 am »
Thank you very much, I knew it had to be something simple.
Offline Esben Oxholm
« Reply #3 on: January 14, 2019, 11:33:14 am »
I add a basic gaussian blur filter (in Photoshop) for fixing these kind of problems.
Unfortunately not possible directly inside KeyShot.
Offline Josip_ZG
« Reply #4 on: January 14, 2019, 12:24:28 pm »
Thank you, Esben, appreciate your reply.
