Surface engraving/sand carving on the surface of glass
Started by guest721, April 15, 2010, 02:17:14 PM
guest721
Hi all,
I'm trying to create a glass material that can have surface engraving (blasted to make it rough) as well as color filling in the surface engraving. I'm in the glass industry and this is a very common thing that we need to show our clients. The closest thing I have tried so far is using the plastic material and adding a .tif file with alpha to the texture channel. The problem that I see is that the plastic material doesn't even look like glass. I also cant make just the engraving look rough.
Any thoughts?
justindustrial
You might try adding surface splits in your CAD program in the areas that you want roughed in, assign them a different colour, then when you import into KS you can copy the glass material to these areas, and increase the roughness for those areas only. Here's a sample:
