Ground plane
Started by Danalevi, January 24, 2019, 08:35:29 AM
Danalevi
Hello,  I am looking to add a curved ground plane in keyshot.  I have generated a curved gound plane model in Rhino.  I can import it into keyshot, but how do I assign it so that keyshot recognizes it as a ground plane.  Any advice would be appreciated.
bharris
Quote from: Danalevi on January 24, 2019, 08:35:29 AM
Right click the geometry and Edit Material. Then in the Material Type drop down, select Ground.
And after you applied a ground material, you can save this object as bip file in the models folder of your resources directory to find it in edit > add geometry and get easy access next time.
Hope that helps.
