Material properties default has changed from prior versions
Started by rod, February 18, 2019, 11:24:53 AM
rod
Not sure about Keyshot 7 but in Keyshot 6 under Materials/Properties the default status of the check box "Blend with Color:" is not checked.  In Keyshot 8 the default status of the box is checked. Please change this default to coincide with future Keyshot 8 and future releases.
Ian Reymond
Hello rod,
Thank you for your post.
I have tested it on my end, and KeyShot 8 unchecks the "Blend with color" box by default. Please make sure you are on the latest version (8.2.80).
You can also delete the KS8Settings.xml file to see if that fixes it for you. The xml file is located in your KeyShot 8 resources folder.
Please let me know if you have any questions.
Quote from: rod on February 18, 2019, 11:24:53 AM
Ian Reymond
There have been no replies to this post for more than two weeks, therefore, it has been locked.
If you still need help please open a new post.
Post closed by Luxion Support Team
