Main Menu
withe diamond
Started by fario, September 16, 2011, 07:48:42 AM
fario
hello,
I am looking for a good environment for hdri rendering white diamonds, please.
Or, what does it have to comply with white diamonds: fire, not too rich for other metal objects support.
Thank you.
fario
elliasp
White diamonds is not about HDRI only but material too.
In GEM material, you have a last part called "nombre d'abbe" and it could be like a level of "rainbow".
Try to play with it and...
Sometimes you have to do 2 renders :
1for the diamonds with the good light
1for the chrome material
Hope it helps :-)
F
fario
#3
QuoteWhite diamonds is not about HDRI only but material too.
very informative
thank you for the comment, I'll try.  :) :)
I started on Photoshop and compositing ...
How is it to assemble two independent reports in Photoshop and be able to set two records in isolation, in contrast, curves, levels, etc ...
Do you have a link to a tutorial for this method, please?
thank you in advance.
Antoine
elliasp
Try to look for a tutorial about "masque de fusion" on photoshop...
Arnaud
http://zbyg.deviantart.com/art/HDRi-Pack-1-97402522 imoh, the 8th gives good results.
In addition to Ray bounces, you need also to play with height / rotate and size of HDRI to get better results on diamonds.
fario
oohhh many many thanks!
i try.
Antoine
Arnaud
A quick rendering made with this HDR
PhilippeV8
Zander85
I love the ring render!  8)
Designer Jewelry
Quote from: Antoine on September 16, 2011, 07:48:42 AM
hello,
Thank you.
fario
good render for this diamond.
Bravo!
Antoine
