Solid Edge import problem
Started by respinosamm, March 15, 2019, 05:30:31 AM
respinosamm
I have Keyshot Pro 6.3. I have no problem opening Solid Edge models in KS when I start from the SE add in,  but when I try to import them directly to a different KS session, I always get this Import Error message:
"C:/.../Filename.par" does not contain 3d geometry.
You may need to export polygonal data from your modeling system.
The workaround is to open the model with the add in, save it as .bip and then I can insert it in a other KS rendering.
Not the fastest way to do it.
Does this error occurs if this file is stored in simple path like C:\temp?
Maybe the ' in the path force the error?
Do you use a CAD combined license or a regular HD or Pro version?
Hope that helps to find the right way.
