Plastic transparent problem
Started by kwaikeong1402, March 19, 2019, 07:11:05 PM
kwaikeong1402
Pls help me check why did see plastic transparent got black? Is shadow issues or settings?
Regards,
Len
kwaikeong1402
If I set 1 and 2 you'll see that the whole thing is white
kwaikeong1402
Aneurismone
What is your lighting mode? are you lighting the scene with only an hdri?
kwaikeong1402
designgestalt
how about your Global Illumination settings?
can you send a screengrab on your  lighting settings?
Ian Reymond
Hello kwaikeong1402,
Thank you for your post.
May I ask which exact version of KeyShot are you using? You can find that by going to Help >> About....
May I also ask, which lighting preset you are using? You can find that by going to the Lighting tab in the Project window. Would you be able to send me a screenshot of that Lighting tab?
Quote from: kwaikeong1402 on March 19, 2019, 07:11:05 PM
Regards,
Len
I recommend you make sure you're in product lighting preset. You can do this by going to the lighting tab on the right-hand side of your screen. This will enable both Global Illumination and increase Ray Bounces which will help with this scenario.
