Author Topic: Avoid planar stretching at 90°  (Read 2047 times)
Offline raglo
« on: April 23, 2019, 08:03:05 am »
As demonstrated in the attachment, labels stretch along axes that they aren't parallel too, but is there a way to stop them from being visible on surfaces that are at a 90° or higher angle?
Re: Avoid planar stretching at 90°
« Reply #1 on: April 23, 2019, 08:31:23 am »
Looks like planar mapping, set the Depth to something slightly more than 0.
Offline raglo
« Reply #2 on: April 23, 2019, 11:30:05 am »
The depth slider doesn't seem to do very much in this situation
« Reply #3 on: April 23, 2019, 11:36:52 am »
I usually set it for .01 and uncheck Two Sided, mapping mode to Planar. That should prevent this sort of behavior. Can you post screen shots of your Lable settings?
« Last Edit: April 23, 2019, 12:37:38 pm by mattjgerard »
Offline raglo
« Reply #4 on: April 23, 2019, 11:08:01 pm »
Thank you so much! This fixed it. I needed a really low depth value. The slider was making the value too large to see that effect.
« Reply #5 on: April 24, 2019, 08:07:53 am »
Great to hear!
Offline Will Gibbons
« Reply #6 on: May 28, 2019, 12:51:49 pm »
When depth is 0, it's actually infinite, so by adjusting the depth to a smaller number should work in future instances too!
