Problem with camera settings (for infographic)
Started by Martin Kunev, August 14, 2019, 02:01:34 AM
Martin Kunev
Hello. I am having a problem with setting up the camera settings so the render matches with my graphic.
Let me elaborate.
I am creating an infographic (see example)  and I have to make renders for it (in toon) so that all of them are in the same perspective and viewed from the same angle. I want to make my renders with as little perspective as possible, so the lines are parallel (similar to orthographic).
The issue that I am having is that when I set up the render camera (see picture), the outcome still doesn't match the lines like it is shown in the desired result.
I hope I explained it properly.
I don't know what I am doing wrong or how to fix it.
Please help.
Thank you in advance.
jet1990
little bit late to this. Is the ground image a backplate image? if so, that could be why as the perspective isnt matching. try adding a flat ground plane and pasting your blue image to that.
