Author Topic: Enviroment change after save the file.  (Read 2076 times)
Offline FulvioStats
  • Newbie
« on: September 28, 2019, 02:32:17 am »
Hello, I'm having a problem with a scene where I'm using "Los Angeles Sunset 4k". I set up "turbidity" on value 2 and I got the light I want to have. Then if I save the file and reopen it the light scene is totally different. To get back to the original light I need to set up "turbidity" on another value and then came back to "2". My problem is that I'll need to send the file to a render farm and the scene will look totally different due to this problem. Do you have any advice about how to fix this bug? thanks
« Last Edit: October 28, 2019, 03:51:06 pm by Justin A »
Offline Eugen Fetsch
  • Sr. Member
    • www.camomiles.de
Re: Enviroment change after save the file.
« Reply #1 on: September 28, 2019, 03:46:29 am »
As a quick fix: save the environment to an external image like EXR, import it back to the library and apply it as new environment.
Offline FulvioStats
  • Newbie
« Reply #2 on: September 28, 2019, 01:29:04 pm »
Thank you but also this not working... As soon. it saves the hdr already change the color. I think is a software bug but I don't know how to find an alternative solution.
Offline INNEO_MWo
« Reply #3 on: September 29, 2019, 04:28:44 am »
Hello FulvioStats.
I can't replicate this issue on KeyShot 8.2.80. I used a simple cube in a scene with centimeter as unit system. Even if I take some changes on the HDRI with turbidity parameter or the ground color (parameter of sun & sky) and with/without re-calculating the environment - after saving and re-opening the scene, I can see the last parameter, but didn't noticed any issues.
You'll find my scene attached.
Perhaps you can replace the geometry of your scene with a simple part and post it here? So we'll can take a look into it.
Hope that helps to find a solution.
Offline Justin A
  • KeyShot Support
  • Jr. Member
« Reply #4 on: October 28, 2019, 03:50:58 pm »
Due to inactivity on this post it will be set to RESOLVED and closed. If you are still having the same issues please open a new thread on the forum or contact us direct at [email protected]
Thank you
