Composite Node - Blending to procedural marble for a diffuse
Started by zooropa, November 09, 2019, 10:01:17 AM
zooropa
Hi. I am trying to blend (multiply maybe) two different procedural textures.
The problem is that when assigning the second texture to background (the other one is connected to source) both of the procedural nodes get the same values.
Do you know if the composite node allow me to mix two procedural textures.
The way as you described is correct. One texture goes to background and the other above as source. The combination is the job of the blend option. Choose multiply or another till you like it.
You can also share your test scene one a simple shape. So we can help you better.
