After testing keyshot9, it is found that GPU usage is less than 100% when GPU rendering is used. When rendering with CPU, GPU takes up 100% of the total, which causes the computer to jam.
GPU rendering is currently unable to render 16000 * 9000 resolution, or even more resolutions, which makes GPU unable to be used in work.
Use GPU to render webxr. After rendering a frame, you will stay for a long time before you continue to render the next frame.
After rendering the image and clicking the green √ in the upper left corner, keyshot9 will not respond for a period of time.
