Fuzz Node bugg?
Started by Paul Lang, December 19, 2019, 06:04:07 PM
Paul Lang
Is it normal that when you turn off/hide geometry in the scene tree that contains a fuzz node that when you turn it back on you have to re-execute the node. For me when I hide an item containing fuzz and turn it back on the fuzz is gone and have to click execute again.
cheers,
Paul
KeyShot
It is a good point. The reason it works this way is that hiding the fuzz will remove it and save memory. If you have a scene with a lot of model sets with fuzz it would use a lot of memory if all the fuzz was created. However, I can see that if you are hiding / unhiding the fuzz as part of your workflow then it would be nice to have it cached. We will think about it.
