Can i do it with keyshot ?
Started by Uno, December 29, 2019, 01:55:20 AM
Uno
Hi guys, tell me please
Do you know have a possible do this material with Keyshot ?
P.S: Sorry for bad English if what, i'm from Russia
Yes. I can reproduce it with an advanced material and a vdb texture.
Uno
If you could me explain it more details it was be great  ;D but you got me direction already, thank you for it  ;)
Uno
I understood, i need vdb_cloud pack and translucent(advance), right ?  :)
yes - the 3d vdb cloud should drive one of the transmission channels. (maybe a high scaled noise texture can do the same?).
If your tests doesn't guide you to the results you want, then play with a scattering media - use the vdb cloud for the density. Add another sphere (duplicate the sphere, unlink the materials and scale the new sphere a bit, e.g. 1.1) and use a clear plastic from the library (and obviously tweak it to your liking)
I have no access to a KeyShot, yet. Which version do you running currently?
DMerz III
 :) Please share your result when you finish! Can't wait to see how it turns out. Might have to give it a try myself.
Finema
Here my test with Scattering medium and 2 spheres.
#7
and I guess if you slightly increase the transmission roughness of the clear plastic, you'll get closer to the result you want?!
What does it looks like, if the vdb cloud is larger than the sphere?
Esben Oxholm had made a great webinar about the scattering media: https://www.youtube.com/watch?v=JK0OmSdEfWE
Finema
yes sure.  ;)
I've join the .bip in my post. Uno can improve it if he wants. :)
Great solution Finema.
I tweaked it a bit. ut I am sure, that it can be pushed a bit further.
PS: a happy new year to ya all!
So, here's my final result.
Uno
Hi all guys, Happy New Year 2020 !!!  :D
Thanks a lot all, your advises was so helpful ! After holidays i'll try all your advises !
Finema, thank you for example and shared file !
All you much helped me !
