You can drive through a fade texture and a color-to-number node the bump height. Or you can use the fade texture as a mask to clip the bump texture.
You will see this solution in the ice glass scene from the default scenes in the library.
Hope that helps.
P.S. written with a mobile device so I can’t share an example scene
